I'm reconnecting my SAFC, SAVCR, & HKS turbo timer & ran into a issue. Some of the wires need to be connected to the same ECU wire. This seems like a non issue; however, I noticed that the RPM's on my SAFC & SAVCR were slightly off with my last install. Is there a certain distance that two wires should be spliced apart or can thy be intertwined at the same point?
Thanks
What is the procedure for soldering 2 wires onto a single - Shorebreak01:28:20 08/12/11
